5spd conversion questions?
I was wondering if anyone has cheap sources for the input gear for the T-Case, and also the pedel linkages/pedeal itself?
Also I remember somewhere on the web that a Ford clutch/flywheel will work on the NV4500, is this correct?
I put the clutch disk on the splines of my NV4500 and it lined right up, I'm just not sure about the flywheel?
Any information would be great!
Thanks
Thanks
I don't know if the ford flywheel will bolt to the cummins, but the 29 spline input shaft and bearing for the t-case I got through Rockland standard gear (search google for there website). It was the best price I could find, input shaft was $212, and the bearing was $38, you need both.
Pedals - ebay or the junkyard.
This is where I get all of my T/case goodies. http://www.transfercases.com/
GR40RCapri
19
09-13-2006 10:55 PM
