5 spd wont shift
Old 12-09-2012 | 05:45 PM
fred steen's Avatar
5 spd wont shift
97 5 spd, i have to double clutch to get it into gears, this just started. 200,000 miles and i do not know if the clutch or tranny has been worked on before..
Please Help
Old 12-09-2012 | 05:58 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Does it grind when trying to shift??.Happens in all gears?I have had these 5-speeds torn apart..Maybe worn shift forks..
Old 12-09-2012 | 07:29 PM
Tate's Avatar
Synchros wearing out.
Old 12-09-2012 | 10:15 PM
fred steen's Avatar
Please Help
does not grind, if synchros what kind of cost to repair
Old 12-10-2012 | 06:49 AM
jstone44720's Avatar
If it is working nicely when double clutching, but otherwise not so much, ensure the hydraulics are in good order. When my hydraulics died, I could shift while moving with double clutching, but had to turn the truck off to get it into reverse.
Old 12-10-2012 | 07:37 PM
9812vram's Avatar
Sounds like the synchros are on their way out. Double-clutching equalizes input and output gear speeds before the shift - same thing the synchros are supposed to do. Repair means Trans Remove-Rebuild-Reinstall. Cost will depend on where you source your parts and whether you do it yourself or take it to a shop...
Old 12-11-2012 | 11:27 AM
infidel's Avatar
If the incorrect tranny fluid was used the syncros will fail.
The only fluids compatible with the syncro material are Castrol Syntorq LT(not Syntech or Syntorque) or Amsoil MTG
Old 12-12-2012 | 06:23 PM
traverler48's Avatar
When mine got hard to shift the stop rings or blocker rings some call them on the syncro's was worn. When the coller slides aganist the ring it is suppose to stop the gear from turning so it will slide on. There is suppose to be a space between the OD of the ring and gear the braking or stopping part is on the ID. If there is no space then the ID of the ring is worn. Mine was 2nd, 3rd and reverse. I do agree with infidel about the lube. You are lucky mine only had 115K on it but 90% of it was towing.
Old 12-13-2012 | 07:47 AM
patdaly's Avatar
^^^^^^^^^^^ This, especially since you said it started suddenly.
Check those Hydraulics.
Old 12-13-2012 | 08:05 AM
I'm going to have to check mine also...Mine is starting to get hard getting into reverse and 2nd gear..Also not very easy getting it into the other gears..At over 250K miles...Maybe it's tired out...I had this trans partly torn apart and the synchros looked better than my orginal trans...
mxmike27
11-05-2009 03:00 PM
pmtg
09-07-2006 11:54 PM
raybob_99
04-04-2006 04:31 PM
NCTURBOS
18
10-29-2005 12:07 PM
Quick Reply: 5 spd wont shift
