5 out of 6 injectors leaking!
how did u find out they're leaking? cause i have a stain near inj #5 and 6...but i think the oil is just leaking out a tiny bit from the valve covers..i cant tell if it smells like diesel fuel
I have changed my valvecover gaskets and cleaned everything off drove it alittle while and checked again and 5 of the injectors where leaking. It's wet around the bottom of the injectors and on #4 it's standing around the injector and running down side of the block.
I will assume you just put in your 370's...because a leak really should not have developed, if they sealed when you initially installed them.
With that assumption...I found when I replaced my injectors...there was rust and debris that fell down on the sealing surface of the head, when I removed the original injectors. I found this, by taking a peek down the hole after I removed them...and knew there was no way the new injectors would seal with all the rust and debris down there.
So...I rigged up some 1/4" plastic tubing to my vacuum cleaner, and sucked out the holes. Everything sealed up perfect for me. So if my assumption is correct, and you just installed new injectors...might want to make sure the holes are cleaned out, before you re-install the injectors with new washers.
Take some emery paper and clean up the return line header where it meets with the injectors when you change washers. I had 3 leaky injectors I mucked around with for a couple weeeks until I did this. Been leak free ever since.
Originally Posted by plow
berner how did your truck act with 3 leaking? did it knock, run rough, lowpower anything like that?
lilsuzuki4x4
09-01-2011 01:50 AM
