47RH 2wd to 4wd conversion. Need help
Old 10-06-2009 | 04:22 PM
stevectd's Avatar
Okay, so the tranny in my 95 12V 4x4 is slipping and needing a rebuild, I scored a 95 2wd tranny for super cheap. How hard is it to change the good 2wd to work in my 4wd. I am assuming take off the tailshaft and swap output shafts. Is there any special tools I'm going to need. Thanks.
Old 10-06-2009 | 05:41 PM
Redliner's Avatar
not for just the rear section. if your gonna go through the whole trans you will need some unless you have a press....
Old 10-06-2009 | 07:16 PM
Fred Swanson's Avatar
If you're wanting to take the new trans and use it, just unbolt the tail housing and swap them over. If you wanted to get into the swapping of tailshafts, there's one nasty spring in there, that will require a shop press to release.
Old 10-06-2009 | 07:49 PM
stevectd's Avatar
That's what I was hoping for, I am going to build the one that I'm taking out so I just need to get the new one in cause I can't afford the downtime right now. Thanks.
93Fury
03-31-2010 01:33 PM
Jordan5687
02-18-2009 02:48 PM
TexasHardcore
08-29-2004 12:20 AM
1320
05-06-2003 06:30 PM
vagabonds2
01-23-2003 08:34 PM
Quick Reply: 47RH 2wd to 4wd conversion. Need help
