47re Won't shift at wot
Old 12-29-2008 | 11:59 PM
j_k_auto's Avatar
I am wondering why it will not shift at wot. If I leave off a tad it will shift perfect through all the gears.
I was searching this for awhile and came up with some questions.
I am still wondering what does the tps actually control? Why does it have to be at 1-1.2 at idle and 2.2-2.9 at wot? ( I do have a standalone ats valve body and can check what the low & high settings are).
Does the tv cable actually change the upshift? I did find out it is also a kickdown cable if I am right.
I am tring to figure out if my problem is in the standalone or the adjustments on my linkage.
thanks
Old 01-01-2009 | 03:36 PM
dozer12216's Avatar
Throttle cable is a factor in shifting. Lever on tranny must be fully forward at closed throttle. Shorten cable to lower upshift points. Hopefully the VB is correctlly calibrated. All info is contained in the FSM.
Johnmesich
01-11-2014 09:34 PM
DragonSlayer
17
05-14-2010 09:38 PM
nathan04
12-13-2007 10:12 PM
greenworks
12-20-2004 07:44 PM
cLAYH
02-07-2004 01:28 AM
Quick Reply: 47re Won't shift at wot
