47re vs 47rh
Old 01-27-2009 | 11:29 PM
highdrive's Avatar
47re vs 47rh
What are the plus and minuses of a 47re compared to a 47rh when used for towing application ?
Old 01-28-2009 | 07:59 AM
dozer12216's Avatar
Neither will replace the other in application.
The RH has minimual electronics and uses a mechancial governor.
RE has a electronic governor added. Operated properlly and upgraded either will do job in it's applicable vehicle.
Old 01-28-2009 | 10:44 AM
John Faughn's Avatar
Its easy to change in one direction but not the other .
Using the RE in an older truck [ 95 and older RH ] , you need to change computer , wiring harness , sensors ect.
But to put the RH in a newer truck [ 96 & newer RE ] , you just need to fool the computer .
One of the guys here [ is in the bis. of working with modding these trucks ] went to Goerends , had a built RH , and put it in his 12v around 97-98 .
I forget the why he went that way .
Old 01-28-2009 | 10:46 AM
infidel's Avatar
I've heard the sled pullers and drag racers say they prefer the RH.
Need95-00CTD
08-27-2007 02:10 PM
njmaier
13
04-27-2007 10:16 PM
tacoma
06-21-2006 03:41 PM
BoldtsWagon
01-24-2003 11:05 PM
Quick Reply: 47re vs 47rh
