4" catalatyc converter needed
Old 04-15-2008 | 05:47 AM
wildcard's Avatar
i need a 4" catalatyc converter asap the only one i can find is magnaflow and its on back order and cant regester my truck until it has one,
Old 04-15-2008 | 09:17 AM
johnh's Avatar
where are you located?
Old 04-15-2008 | 09:27 AM
1-2-3's Avatar
Just a plain ole guy
What happened to your original?
Old 04-15-2008 | 09:45 AM
snoyes's Avatar
Where are you located at x2. Are you looking for a stock one? Is this because of emissions inspection required?
Old 04-15-2008 | 10:21 AM
jumper's Avatar
Were there really factory CATs in 1994, or is this for a different truck than in your SIG?
Old 04-15-2008 | 01:23 PM
91rangerturbo's Avatar
Try summit racing.
http://store.summitracing.com/egnsea...nresults=false
Old 04-15-2008 | 07:17 PM
wildcard's Avatar
its a 2004 and it came with 4" exhaust (not stock) I just bought it on the weekend Im in ontario canada and we have strict emmisions and I have to have a cat before i can register the truck, im using it for work but I cant register it yet and magnaflow wont have any at the factory for at least 3 weeks or more, and dont know who else make 4" cats. The only one summit shows is the magnaflow for 4"
Old 04-15-2008 | 07:22 PM
Totallyrad's Avatar
There's a 5" in the classifieds. I believe it's a Magnaflow and around $400. There was also a stock exhaust in there a few days ago I just can't remember if it included the cat.
Old 04-15-2008 | 07:44 PM
snoyes's Avatar
Yep, I have the stock approx 4 inch for the 2006, but the shipping alone to old Canada may not be worth it.
Old 04-15-2008 | 09:49 PM
wildcard's Avatar
well i have a usa mail box in mi zip 48039 if you could get me shipping that might be perfect,
Old 04-16-2008 | 12:17 AM
dslpower's Avatar
4" Cat
I have my stock 4" (i think it 4") off my 95. It has some pipe left on each end iirc. Will go outside before going to work and check. If you have a US mailbox it will be less expensive to ship.
If you can get by inspection without the internals (just the shell for looks), it would weigh less to ship.
Old 04-16-2008 | 03:02 PM
CMooreBLKSMK's Avatar
I think the 2nd gens all came with 3 1/2 exhaust, so double check the size.
Old 04-16-2008 | 10:05 PM
wildcard's Avatar
i just found out and correct me if im wrong the 04 does not come factory with a cat, if no cat stock then i might beable to get away with out one I have to look into this.
Old 04-17-2008 | 06:34 PM
Totallyrad's Avatar
Early 04 did not, 04.5 does.
Old 04-17-2008 | 08:39 PM
madhat's Avatar
Administrator/Jarhead
Correct.
The 04.5 has a build date after Jan 04. Find it inside the driverside door jam.
If you have a 04.5, I personally know where there is a 4" cat... Not many miles on it, either... PM me if you need it.
Quick Reply: 4" catalatyc converter needed
