2500 gas bell housing same as diesel?
Old 07-27-2007 | 09:13 AM
WideOpenThrottl's Avatar
Are the bell housing (1995) the same between a 5.9 gas tranny and the 5.9 cummins tranny? (would a gas tranny bolt up to a 5.9 or 3.9 cummins?) If so how different are the internals?
Any info would be great,
Thanks, Tim.
Old 07-27-2007 | 12:18 PM
patdaly's Avatar
Nope, not only are the bellhousings diff, I believe even the 5.9 gasser uses the 42R series Vs the 47R tranny.
V-10 gasser is supposedly the same.
Old 07-27-2007 | 04:00 PM
ChargerLighting's Avatar
W/the starter there is an issue too...the CTD starter has 3 bolts to mount it, a gasser starter only uses 2.
The 42-series trans I've only seen in a Dakota that I had ('97). & my '97 1500 w/318 has a 46RE if I remember right. I would hate to see a 42 in even a V6 Ram...
Old 07-27-2007 | 04:34 PM
jughead's Avatar
i think the v-10 trans is the same pattern as the diesel.
Old 07-27-2007 | 08:01 PM
gmctd's Avatar
The gasoline-engine starters are mounted low, below the crank center-line to clear the driver's-side cylinder-bank - Diesel starter is mounted just above the centerline - pattern is not same, even in the V10 - 47\48RE internals are essentially identical for V10\Cummins - 46R internals can be upgraded to 47\48 internals - '88-92 trans used same bolt-pattern and starter mounting location as gassers (patooie!), but had no TCC
J Lent
60
11-03-2009 09:14 PM
tboling
12-09-2005 05:25 PM
ChrisM55
09-27-2005 10:43 AM
95black2615
07-21-2005 09:06 PM
Halnrvs
0
03-21-2005 04:23 PM
Quick Reply: 2500 gas bell housing same as diesel?
