24V intake on a 12v
Old 01-29-2008 | 03:58 AM
White Rat's Avatar
24V intake on a 12v
Anyone know if a 24 valve intake manifold will fit on a 12 valve? My friend is swaping a aftermarket on to his truck (01') and I was wondering if I can use his on my truck.
Cheers
Old 01-29-2008 | 10:00 AM
NMCTD's Avatar
It will bolt to the intake manifold, but I think the piping is slightly different, so you might need to either modify the intermediat pipe or get different boots.
Old 01-29-2008 | 11:14 AM
turbos10's Avatar
Yes
I did this on my truck, and there is a pic in my album. The ports are different and you will need to take an hour or two with a grinder to get it to fit. You DO NOT want to grind the ports to match the gasket as you will remove too much material. If you look at the 12V head you will see the port is significantly smaller than the manifold port, or at least it was on mine. Basically, you just need to grind the round ports top and bottom to make them rectangular. It took about 1/8" top and about 1/4" in the corners to square it. Then blend it back about 1/2-3/4" so you get a good transition. With a good carbide cutter you can do it in an hour or so. Leave as much material as you can so you have a good sealing surface.
Old 01-29-2008 | 08:52 PM
Tate's Avatar
You're talkning about the exhaust manifold, he's talking about the intake air horn.
Old 01-29-2008 | 09:21 PM
turbos10's Avatar
hehe.....I see that now.....barely read the post since the title said manifold and there is only one on the cummins.
Old 02-01-2008 | 09:53 AM
White Rat's Avatar
I'll try it out, I can have a sparky at work bend me a new mid pipe if I need it.
turbos10 - That info doesn't help now, but it will come in handy later if I need to replace the exhaust.
Cheers
Old 02-01-2008 | 08:31 PM
bob4x4's Avatar
There is no advantage to using the 24v horn unless your 12v had egr.The next issue will be tight clearance at the master cylinder.The angles are diff between the 2 as well.
Sorry I do not have a good pic of the 12v horn to compare
Bob
JBradley500
04-27-2010 09:08 PM
king5335
26
01-17-2010 07:57 PM
1bad93
03-21-2009 06:12 AM
buddy26
16
01-14-2009 07:29 PM
thewished
0
11-04-2007 09:51 PM
Quick Reply: 24V intake on a 12v
