2200+rpm miss
2200+rpm miss
Any more than about half throttle at or above about 2200 rpm there is a loss of power/missing.If you are easy on the throttle it is fine.Just replaced fuel filter and over flow valve,any other ideas would be great.Thanks
check and see if there is air in the fuel lines. Do you have a muffler or a cat on your exhaust? if you do it maybe clogged. another thing that should be checked is timing, it may have sliped.
Truck was stock when I purchased it so all mods are new.The timing is next on my list.But for the last month all I have done is work on/dump money into this truck so I think it will stay parked for awhile.Thanks Justin
Buffalo
12-02-2007 08:35 PM
