215 Pump
215 Pump
Is the only difference between my 180 hp and a 215 hp motor is the injection pump, if it is what would the cost be to get my pump up graded to a 215 and is it something a backyard mechanic can install in his garage, or do I need special tools?<br>I already have a #10 plate to go in><br>Thanks Trickytrae
Re:215 Pump
Trickytrae:<br><br>As I understand it, the 215 pump has a different cam and<br>also different barrels and plungers than the 160 and 180<br>pumps. However, there are shops that can take a 160 or<br>180 pump and really make them perform. Scheid Diesel<br>and Piers Diesel are two that I know can do it. The costs<br>of modifying a 160 or 180 pump are almost as high as<br>buying a 215 pump. FYI, J.P. at Scheid Diesel can give<br>you more information on this if you want to call him.<br>His toll free phone number is: 1-800-669-1593.<br><br>--------<br>John_P
Re:215 Pump
Unless you are power-crazy, you can get away with not upgrading pumps... With a correctly-tuned setup including a new fuel plate, some 215 injectors, new delivery valves and a GSK... You will forget all about that 180hp rating. I just don't think there is justification to having your 180 pump upgraded... Plenty of people have made plenty of power with a 180 pump.
12valve
31
12-24-2005 03:28 PM
12valve
11-29-2005 09:48 AM
Boondock
04-29-2005 12:28 AM
