1998 12 valve won't idle
Old 05-27-2012 | 09:20 AM
BRAD HALL's Avatar
HEY GUYS MY DAD IS ON THE ROAD PULLING HIS FIFTH WHEEL AND HIS TRUCK WILL NOT IDLE WHEN HE STOPS AT A RED LIGHT HE IS HAVING TO RIDE THE BRAKE TO KEEP THIS THING RUNNING BTU ONCE YOU GET ABOVE AN IDLE IT RUNS LIKE A CHAMP ANY HELP WOULD BE GREAT AND THANKS IN ADVANCE
Old 05-27-2012 | 09:53 AM
BigIron70's Avatar
Cummins Guru
Turn up the idle screw on the injection pump. Located to rear of the pump by the lever. 10mm loosen lock nut on the bottom then turn screw 1/2 turn cw viewed from bottom that should do it. Hold screw from turning then tighten locknut. Don't forget to tighten locknut or the screw will rotate out and idle rpm will go down again. Set to 750 to 800 rpm in gear ac on at operating temp is the spec.
camodiesel2500
06-19-2016 10:47 AM
89f150
11-18-2008 08:00 PM
Turbo Deeezle
06-27-2005 08:42 PM
dieselman24
05-22-2003 04:00 PM
phildog
04-02-2003 05:44 AM
Quick Reply: 1998 12 valve won't idle
