190 HP freightliner P pump?
Are these decent pumps to do mods to? I ran across someone that has one and was thinking of buying it and the timing case to convert a VE pump motor. Thanks for any help-Nick
How similar do they look? If I drive my 96 there and compare it would I be able to tell the difference? Any #'s on a 7100 that gives it away as such?
I was told it came off of a 5.9 that was in ford truck and when I posted the pump # on TDR (0 402 036 747) I was told it is a P3000. The biggest external differnance I see is that this one has a plate on the bottom of the pump held on by bolts instead of soft plugs like the 7100's do. After comparing them side by side there are other small differences, but the plate on the bottom is the biggest one. On mine once I took it apart the Barrels, DV's and DV holders are also all different.
trucksforu
08-01-2005 09:57 PM
gman07
07-02-2005 10:10 AM
