180 and 215 7100 injec pump
Old 07-16-2006, 11:07 AM
wana12v's Avatar
from my understanding the 180's and 215's cant go to far on rack travel with out retarding fuel timing. however im not sure what your trying to acomplish but 600cc's is a ton of fuel. it also depends on what injectors you have. but a tuned 180 with full cut dv's and a good set of injectors 5X14 ddp's or some 5X16's and you definately have enough fuel for 500+ hp. I have heard or 500cc's being had out of an 160 with no plate and a stock cam
Old 07-16-2006, 12:21 PM
Forrest Nearing's Avatar
I've got a set of DDP4's... would like at least 600rwhp on diesel. I've got a 180 pump and a 913 215 pump
Old 07-16-2006, 03:03 PM
Rhino's Avatar
I don't think it is the Helix that has anything to do with the variability of the timing of a 215. The top of the plungers have a groove cut in them which accounts for the variability of timing of a 215 pump.
The P&B assemblies are definitely different between the 215 and 180 pumps.
This past winter I had both a 215 and 180 pump at the pump shop for a little work and I was told both pumps had the same cam. I have also heard from several reputable sources that the cams are different between the 215 and the 180 pumps?
Old 07-16-2006, 05:16 PM
rhino 660's Avatar
what delivery valves would you guys recomend. ie 181's 191's laser cuts
with the mods i got. planning on 40 HP injectors and a BD power single turbo.
Old 07-17-2006, 03:12 PM
wana12v's Avatar
i would stick with the 913. set up with 17-19mm of travel. full cut dv's 4k springs those ddp4's and about 24* of timing with a set of twins or an 66mm(or larger) single and you should have 600. A little nitrous and a big single would be a fun setup imho
Old 07-27-2006, 02:13 AM
Jim Fulmer's Avatar
Originally Posted by Forrest Nearing
what about 600+? could I stick a 215 cam in a 180 pump and get the same effect?
thanks,
Forrest
Tha cams are the same as per Brady Williams (I.I.) and my 215 is setting at 20.5 mm's and is quite salty there.........no it has 12mm's in it and will stay that way.
Jim
oldblues
03-23-2011 12:05 PM
freds89
11-28-2009 06:11 PM
Bram
06-10-2008 08:43 AM
stock600
02-29-2008 03:45 PM
12valve
12-22-2006 02:28 PM
Quick Reply: 180 and 215 7100 injec pump
