180 and 215 7100 injec pump
Old 07-11-2006, 07:36 PM
blitz_81's Avatar
my injector pump is leaking oil on my truck and am looking into just buying another one. i found a 180 pump for pretty cheap and was wondering what i would have to do to it to get it back to a 215 pump or any mods that i could do to it. thanks for the help.
Old 07-12-2006, 09:17 AM
plow's Avatar
were is it leaking at?
Old 07-12-2006, 10:32 AM
Forrest Nearing's Avatar
it's not just a calibration thing, there are considerable internal differences between a 180 and a 215
Old 07-12-2006, 11:03 AM
gunracer1's Avatar
the more i learn, i am starting to figure that the only real differance is in the helix cut in the plungers. but i have not pulled one apart so i can't say for sure.
Old 07-12-2006, 08:06 PM
blitz_81's Avatar
the pump is leaking oil out of the injector pump timming plug. the threads in the pump were striped out. i put some jb weld around the plug and have pretty much stopped the leak but would like to fix it right. another question is where would i purchase some lazer cut or high flow dv's?
Old 07-12-2006, 09:11 PM
I've heard lots of talk about a timing curve? any truth to that?
Old 07-12-2006, 09:49 PM
Cowhand's Avatar
I've heard different cam, barrels and plungers.
Old 07-13-2006, 12:52 AM
12valve's Avatar
Ive FELT the difference!!!
Old 07-13-2006, 12:56 AM
12valve's Avatar
I PMed you!
Old 07-13-2006, 07:39 AM
gunracer1's Avatar
as i understand it, the helix cut in the plungers of the 215 do act as a timing advance at part throttle. but work at retarding the timing at full travel. and that 215 pumps work best at 17mm of rack travel. and pumps with out the helix can go on up to 21MM of rack travel. so i really need to play with some pumps i have here at the house. god i have to get the shop done.
Old 07-13-2006, 10:01 AM
I thought 215's were good at 21mm too or is the duration so much that EGT's negate power gains?
Old 07-13-2006, 10:38 PM
12valve's Avatar
How do you guys measure rack travel??
Old 07-14-2006, 10:25 AM
if it's off the truck, venier calipers work well
Old 07-15-2006, 05:54 PM
wana12v's Avatar
at 21mm it will make a ton of fuel(600+cc's) but due to the helix it retards fuel timing. 17mm will make 450 cc's wich is plenty for big hp 500+ im not sure how a 180 acts. however the cam in a 215 is great and put in a 160 pump you have a race pump on the cheap
Old 07-15-2006, 11:40 PM
what about 600+? could I stick a 215 cam in a 180 pump and get the same effect?
thanks,
Forrest
Quick Reply: 180 and 215 7100 injec pump
