12v verses 24v
Old 03-20-2004 | 07:01 PM
FANZDSLPWR's Avatar
12v verses 24v
HEY WHATS GOING ON HERE? I DRIVE MY 96 2500 4X4 AT 75MPH AND I AM AROUND 2300RPM. TODAY I DRIVE MY UNCLES 2001 3500 AND AT 75MPH I AM AROUND 1700 RPM. IS THE GEARING THAT MUCH DIFFERENT?
Old 03-20-2004 | 07:05 PM
pro puller's Avatar
Sounds like 4:10 vs 3:55 ratio.
Kurt
Old 03-20-2004 | 07:24 PM
Captain's Avatar
thats about it. my dad and I have identical trucks except his is a 3.55 and mine is a 4.10. Thats almost what I read at those speeds vs his.
Old 03-20-2004 | 09:07 PM
98rammer's Avatar
that sounds like bigger tires and/or overdrive unit. mine with 3:54s run 2000rpms @ ~69mph with 245/75 tires. dad's old 94 auto 2wd that had 4:10's ran just over 2100rpms at 70mph.
Tom
Old 03-21-2004 | 07:38 AM
FANZDSLPWR's Avatar
YEA A 4.10 REAR MAKES SENSE IN MY TRUCK BUT MY TRUCK IS A 4 SPEED AUTOMATIC AND I THOUGHT 4.10 DID NOT COME IN A AUTOMATIC DODGE
Old 03-21-2004 | 09:19 AM
98rammer's Avatar
nope, the 4:10 is available in both auto and manual. where you're probably getting confused is the limited slip which wasn't available with the 3:54/3:55 gears; however, it could actually be ordered if you checked off both boxes.
man, 1700rpms at 75mph must have tall tires or an overdrive unit. how does that thing even move in OD without fueling enhancements?
Old 03-21-2004 | 09:57 AM
MnTom's Avatar
Hey Rammer- Mine has the limited slip rear end and it is the 3:54.
Old 03-21-2004 | 06:09 PM
98rammer's Avatar
yeah, i guess it wasn't listed as available, but you could check off limited slip and 3:54 and it would go through?--something like that before. i have 3:54's, but no limited slip....really wish i did!
Tom
Old 03-22-2004 | 03:46 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
3.54 was optional from the factory with a Power Lok or Trac Lok LSD from 94-2002 thats where i got mine.
Old 03-22-2004 | 08:14 PM
Cowhand's Avatar
Got the 4.10's and LS behind my auto......
I turn 2K RPM at ~72 MPH. Then again, I am running a 37" tire.....
Old 03-30-2004 | 10:55 PM
WHIFF's Avatar
Is there really that much benefit to having the LSD? I have the 3.54 but no LSD. I was told I couldn't get one.
Old 03-30-2004 | 11:24 PM
jaconst's Avatar
I know my 3.54 LSD has extra leaf and sway bar for rear and anti- lock 4 wheel
Old 03-31-2004 | 12:11 AM
ddestruel's Avatar
LSD's make a significant difference especially on ice and snow when i added mine it improved my drivability to the point hat i ussually drove around in 2xd with the hubs locked and had alot less problems with spinning out.
Or you can look at my picture files and see what a difference they make
tennman0258
17
07-22-2007 11:20 PM
fishin fever
03-30-2006 12:02 AM
fishin fever
11-28-2003 05:07 AM
moneyman
09-11-2003 02:12 AM
03-27-2003 09:15 PM
Quick Reply: 12v verses 24v
