to 12v or not to 12v?
Old 10-08-2007 | 04:41 PM
Townsend600's Avatar
am debating selling my truck and buying a 1996 2500 ext cab 12v 5 spd. All stock except the pump has been turned up and has a single stack and a bhaf wheels and tires. Charcoal grey in color good interior. 156,000 miles. Am I crazy, or would this be a good change for me? It will be a daily driver, I plan on upgrading injectors, the pump, fire ringing the head, turbo, and maybe a port and polish by piers. Will it be dependable?
Old 10-08-2007 | 05:31 PM
Box5's Avatar
It will be very dependable and powerful with a few mods, the only question u need to ask is if u want to loose the comforts of ur 04 for a louder, more rugged truck. Take a very good test drive to make sure u won't be complaining later about loudness, or smooth ride, shifting the 5spd all the time, etc.... Not trying to stear u away from a great truck like a 12v, but u do have a 04' which are pretty nice trucks.
Old 10-08-2007 | 05:41 PM
logskidder's Avatar
Your crazy.........unless you need the money. You can make good HP with what you have. The p-pump is good for raw dirty HP,however it can not do the things your 04 cr can. IMO
Old 10-08-2007 | 06:07 PM
96_12V's Avatar
you'll have to consider the fact that your shirt will be lost on your newer truck, since unless you have a firm buyer you're likely never get what you spent out of it. What's wrong with the '04?
As to the '96, and since I have one, there's the illusion that they are cheaper overall. The problem is, it's now an 11 yer old truck, and since most of these have been used & driven hard, the rest of the truck is more of your consideration. It's quite likely, as 96_12V has in the past year, that this "new" truck will nickle & dime you in other areas. These wear out failures get quie expensive and they put a fine point on use and care. I'd consider it carefully, is this really what you want - or an "impulse..."??
Old 10-09-2007 | 12:46 AM
Buckshotram's Avatar
Sounds like you have a pretty nice truck now, I heard you say daily driver so if I was in your shoes I would keep what I have because with a 12v its pretty much you got what you got except for a valet switch but you got to love the adjustability of the CR.
Old 10-09-2007 | 11:09 AM
dieselfuelonly's Avatar
DTR question asker
12 valves are great, but you already have a nice truck, why would you want to get rid of it?
Old 10-09-2007 | 01:06 PM
patdaly's Avatar
I'm in the opposite camp, I can afford a new unit and the price on a 04 would be even easier to swallow.
I chose my 12V for a reason, and that reason is seen in several threads here with people stuck in the middle of BFE with a fuel issue that killed some very expensive stuff.
Yes, mine may nickel and dime me at times, but overall, I am sure I can keep her on the road for a very, very long time with nothing other than my time and tools.
Old 10-09-2007 | 01:38 PM
Blast Chamber's Avatar
I own both an '03 and a '98, and they are very different trucks. The '03 is much more comfortable to drive and makes smoother power; I use it for long highway trips or when towing trailers heavier than 5,000#. The '98 is more coarse and the ride can be rough even with the new shocks. I use it for my daily 100-mile commute to work and for highway trips up to 5 hours. My goal is to keep the local miles off the '03 so it will last until I retire.
They each have their place, although from a reliability standpoint I wouldn't hesitate to drive either one across the country. But from a comfort standpoint, the '03 is the winner hands-down.
03CumminZ4X4
02-02-2008 12:15 AM
Townsend600
10-08-2007 06:05 PM
CTD2001
02-03-2007 02:30 PM
apache
10-27-2004 09:53 AM
