12V Fuel System
12V Fuel System
Well, I finally sprung a big leak - havent had a chance to look at it real good yet but Im pretty sure the problem is with the fuel line(s).
I want to redo the whole fuel system with 1/2" S.S. tubing and Swagelok PB-8 hose. Now, I should know this but does anyone know what size of fittings are in the fuel system (lp, fuel filter, Injector pump).
I know Vulcan Performance sells a kit but I believe that it only goes from the Fuel filter to the Injector pump. Its pretty $$ as well.
Can any 12V guys help me out here?
Thanks.
Thanks.
Injection pump inlet is 14x1.5 or you can remove the helicoil and it's a 16x1.5. I think the lift pump outlet is 12x1.5. I have them wrote down somewhere but can't find them right now. I'm going off of memory. I'll try to find them and post them up tomorrow if they are wrong. i deleted the fuel filter bowl and heater though. I run a baldwin fb 1311 filter base. There is a lot of choices for 2 micron fuel filters with that setup.
RiverRat2
10-15-2019 11:59 AM
Resbum
02-25-2012 06:54 PM
