12v Fuel filter change - won't prime???
Old 09-03-2010 | 10:24 AM
infidel's Avatar
Originally Posted by blackimpala
infidel, I made a cap like that and have tried to use it the last three filter changes, it just will not work for me. I even get air bubbles at the bleed screw. I have left the da-- thing on w/air to it for 5min just will not work.
Floyd
Could be your compressor isn't big enough or your tank is too empty.
With a full tank even a small compressor will work.
You could also have a return line leak inside the tank that doesn't effect engine performance but when you pressurize the tank it pushes air up the return line.
Pressurizing the tank fills the filter from both the return and feed lines.
A fuller tank may cover the leak and allow things to work right.
Be careful with a very full tank though. When you relieve pressure at the tank you can end up taking a diesel bath.
Old 09-04-2010 | 08:36 AM
blackimpala's Avatar
Thanks infidel, I will try it again next filter change.
Floyd
Old 09-23-2010 | 08:52 PM
barngal6's Avatar
Infidel's pressurizing the tank has worked for me sometimes, and other times I've had Blackimpala's experience, so maybe I have that return line leak in my tank. I'll pay attention to how full the tank is and see...
I keep the hoe handle in my truckbox, has come in handy when I ignored
my "empty" fuel gauge before (shame, I know)
Old 09-23-2010 | 09:27 PM
chariotdriver's Avatar
Infidels technique works great and if you have a problem, just pinch off the return line. I'm in his camp, haven't used the primer button since the 90's
cd
MAC702
11-30-2011 05:40 AM
MAC702
02-22-2010 08:56 PM
chuxtruk
04-27-2006 04:09 PM
neal dehmler
12-25-2005 06:48 PM
Quick Reply: 12v Fuel filter change - won't prime???
