12v code reader???
You have to have an DRB scanner to plug into the test port on the 94-96 models. OBD 2 should work from 97-on.
You can do the key on-off-on-off-on trick and count the number of times the check engine light flashes and check some codes this way. IT should at least flash a code 55, means test is done. Any other sequence is a trouble code.
Well now I have to try it on mine... I always heard it only worked on '00+ trucks. Where does it display the codes?
It says here; '94-'96, '97-'98 need the drb tool. http://www.dodgeram.org/tech/dsl/tro..._DTC_codes.htm
CTD NUT
04-05-2005 05:45 PM
NJMurvin
05-10-2004 07:00 PM
