12mm ARP head studs?
Hey, got the studs in couple days ago. Intructions read of all this machine work and tapping the holes deeper and all this. Is this what all you guys are doing? I had never read on this having to be done. I will IF tis a ness. other wise it seems like a lot of trouble. What i dont get is, milling the tops of the rocker blocks will not lower the stud if thier were interferance in the valve cover, so whats the point? Have not re-assembled a cylinder to see because my .20 head gasket still has not arrived. If thiers an issue or interferance prob. wheres it at???? Thanks tons guys
Yes you have to machine the tops of the rocker assy.
I have a set of each. My old skool set, I had to grind the undersides of the valve covers to get them to clear the studs.
My new set, the studs for the rockers are shorter, so you have to machine them or else the nuts won't be able to go on.
Thanks JD730, not a big deal heck thier already off. Did you also have to tapp the holes any deeper? I know you shouldnt, that should be the point of the studs beeing shorter, but the place i bought them just said they to tap a little deeper? Did you.. thanks Ryan
What Id read is theres material at the bottom where the drill went down but its not tapped all the way so you can get a little extra room with a bottom tap.
Obviously you want to be really careful tapping the block so you dont lose the tap in there. There was a thread awhile back that even listed sources for the best tap.
Ya i too seen that measurment, did your measrure correctly with out tapping any further? If so ill just plan to do the machining on the top of the rocker blocks. Thanks guys
Moobesor
06-06-2008 12:27 AM
jmccart
13
05-05-2008 05:17 PM
