Is 10 inHg to brake booster normal
I have a 96 2500 auto 4x4. When I use a hand vacuum pump gauge to apply vacuum to the brake booster only, (all other lines are disconnected) the vacuum gauge will read 10 inHg not more. If I try and apply more It will stay at 10 inHg. has anyone else ever done this. Shouldnt the vacuum keep going up and hold. I tested all the other lines also, the more I pump those the more vacuum i get and it holds. Is there any other test I can do to see if brake booster is bad?
Thanks for any help John McHorney
Originally Posted by livewire
Do I have to remove lines from master cylinder to change brake booster?
Moving the master this way is also the only sane way to change the fuel filter.
robox
09-30-2005 07:15 PM
betsycam
08-17-2004 07:34 PM
