00-02 D60 and AAM Hub Conversion Group Buy??
I keep reading that Dynatrac is comming out with a hub conversion for the AAM axles. I also heard that this same conversion will be compatible with the 00-02 D60 axles as they use the same outer and inner knuckle, spindles, and stub shafts. Can anyone confirm that this kit for the AAM will also work with the 00-02 D60?
Does anyone have any more info on this? Has the kit been released yet? Price?
Also, does anyone have a link to the group buy that I keep hearing about?
Re: 00-02 D60 and AAM Hub Conversion Group Buy??
Dynatrac has been selling the 2nd gen kit for a few years now.....The 3rd gen AAM full float hub/bearing conversion kit has not been released yet - to my knowledge.
The two kits would not be interchangable......The ball joints on the AAM are different than the 2nd gen D60 so the new knuckle would not be interchangable......the inner axle shafts are also a different size and spline....
We don't do group buys here at DTR, too much chance for someone to get burned and lay the blame on DTR.
As to the conversion, the only one I know of is big bucks, in the neighborhood of $2,500,
and you lose the anti lock brakes.
phox
phox
Yes, they do have a 2nd gen kit which is for the pre 00 trucks. This kit will not work on 00+ trucks due to the knuckle change.
phox
phox
Originally posted by blown32
I would sure be interested in the conversion as well as a "group buy" of some type.
Any one have any info on it????
peteygirl
0
03-14-2004 09:10 PM
4x4
02-25-2004 05:14 PM
