Cab/frame differences
Old 12-01-2016 | 11:04 PM
Twinky_Bomb's Avatar
Are all single cab, cabs from 1994-2002 the same? As far as frames, are all the 135" wheelbase(regular cab dually) frames the same from 2WD/4WD?
Got a 1998 C&C 138" wheelbase, 2WD, weighing my options on possibly swapping the cab onto a 135" wheelbase frame. Just looking to get some basic knowledge on cab and frame differneces. Thanks.
Old 12-02-2016 | 08:50 AM
saggonwaggon91's Avatar
If I remember right, the C&C frames are more flat after the cab then the standard frames. They may even be just a bit narrower after the cab. And as you have seen, wheelbase differs. The cab should swap over w/o a problem as far as cab mounts.
Old 12-02-2016 | 02:35 PM
deere country's Avatar
The frames had several changes in 1998 mostly in the front half. The c&c frames are completely different from the standard trucks that came with a pickup box.
Old 12-02-2016 | 09:35 PM
Right. Basically what I'm wondering is if the cab will fit onto a regular cab dually frame, no problem. Also if the front end can be swapped over to a regular cab dually frame.
Old 12-03-2016 | 08:46 PM
SIXSLUG's Avatar
I would think everything would line up with the fenders and cab lengths for reg cabs since they stayed the same from 94-02 for 2nd gens....regarding cab mounts, bumpers etc ..
Old 12-03-2016 | 10:00 PM
Okay. So it should mount just fine to a regular cab frame, any other problems that could occur as far the interior/components mounted on the firewall etc?
Old 12-04-2016 | 05:22 PM
SIXSLUG's Avatar
Sounds like a good question for patdaly or dieselworks...
Old 12-04-2016 | 09:57 PM
Who?
Old 12-04-2016 | 10:47 PM
You could help by giving a better description. You didn't specify the year of the second chassis you talked about. What is it exactly that you are wanting to do?
Old 12-05-2016 | 11:30 AM
patdaly's Avatar
Ok, here goes.
While it looks like the frame dimensions are slightly different between the 135 and the 138" WB ( standard to CC ), the parts book doesn't show any difference in the cab floors where the body mounts are. They do show an adapter frame to body that I don't remember on any of mine, so could that be how they adapt the CC frame to a standard cab?
Anyway, here are the dimensions of the various frames.
Cab/frame differences-97-frame-1.jpg
Cab/frame differences-97-frame-2.jpg
Best idea would be to drive your CC up next to the standard frame and look under it to see how they matched the 2 up.
Best info I can find.
On edit, looks like this info is for standard, non C&C frames, dimensions lay out that the 138 is for a Eat cab short bed truck, not a C&C.
I would almost guarantee you that the standard cab will interchange between std and CC chassis.
Old 12-05-2016 | 09:15 PM
Original post says what I'm wanting to do. Got a 1998 C&C 138" wheelbase, 2WD, weighing my options on possibly swapping the cab onto a 135" wheelbase frame. The frame I'm looking at is a 135" wheelbase frame which would be a regular cab dually, 1997 model.
Originally Posted by patdaly
Ok, here goes.
Attachment 46958
Attachment 46959
Thanks for that info, that's awesome. I'll have to check it out when I can get to a computer, pictures on the phone are all blurry can't really make out the dimensions.
Will all the frames from 94-02 be the same? In other words can I use any 04-02 135" wb frame or do I need to stick to a 98 specifically since that's what year this pickup is?
Old 12-06-2016 | 09:23 AM
patdaly's Avatar
No, Gen 2's aren't year specific, but as you can see, the C&C frames are all 4WD with a dummy axle, while the standard Dually uses the Independent suspension.
I take it you are trying to get rid of the 4 link front end for death wobble?
Old 12-06-2016 | 10:02 AM
richard's Avatar
Like patdaly says, the c&c is the same for both as far as cab mounting. If you need any exact measurements, I have a c&c frame with the dummy front axle outside my shop. Just let me know and ill run out with a tape measure.
Old 12-06-2016 | 04:15 PM
Really bought the pickup as a project thinking I could put a regular bed on it but obviously not. That's why I'm considering finding a 135" wb frame and swapping the cab engine tranny over. If I could I'd like to stick with the solid axle front end, so I guess now that it's settled that the cab will fit on any 135" WB frame from 94-02, can the solid axle front end be swapped over?
Awesome, thanks.
Old 12-06-2016 | 07:45 PM
richard's Avatar
To use the solid front axle you would have to start with a 4x4 chassis. The 2wd 3500 pickup uses very different front end geometry. The solid front axle is used on the c&c truck lust like the 2500, 3500 4x4. But instead of being used as a drive axle, it is only a hollow tube.
Quick Reply: Cab/frame differences
