Sport Lights???
Old 01-02-2005, 01:30 AM
CanuckCTD's Avatar
Sport Lights???
Hey Guys,
I would like to improve the headlights and was thinking the sportlight conversion might be the way to go. Is there a better system and how hard is the conversion for my truck???
TIA
Old 01-02-2005, 01:37 AM
willysrule's Avatar
do a search for the britebox...or the hi-low beam trick that someone else posted...
Old 01-02-2005, 01:55 AM
CanuckCTD's Avatar
Thanks for the suggestion *****. The search wasn't working for some reason when I posted this.
Old 01-02-2005, 04:53 AM
jrs_dodge_diesel's Avatar
When traffic on this site gets high the search feature is turned off automatically to reduce server load.
Old 01-02-2005, 09:59 AM
msing's Avatar
Willysrule the britebox will reilly help you mite find some high end driving lights that would fit in were the factory fog lights go.most driving lights are brite but do not light the road for the long range like 300/500 yards. look at my pics this may not be what you want to do but I now can see at night.
Old 01-04-2005, 12:57 AM
ArcticWolf's Avatar
Geez msing - are those lights big enough? LOL
I went with these from PIAA Click Here
These are their model 520. They're more than bright enough and do a great job in fog/rain/snow and go for quite a distance (more than 1 standard city block - I can light up the side of an apartment complex that's 2 blocks from my house! LOL,
Old 01-06-2005, 06:45 PM
msing's Avatar
Some one told me once bigger is better
Old 01-06-2005, 07:34 PM
gwhammy's Avatar
There is a post on the performance part that rattle_rattle put up about high and low beam if you haven't already saw it. Msing, does the motor pull down when you turn them lights on!
Old 01-06-2005, 11:41 PM
ArcticWolf's Avatar
I don't know but I think maybe if he put his truck in neutral and turned them on, he'd start rolling backwards
Old 01-06-2005, 11:47 PM
msing's Avatar
The 4 on the light bar 100w the 2 little piaas are 35w about 33 amps does not seem to pull down the volts, the stereo does at an idle though but not that bad. these trucks have a good size alternator.
Old 01-07-2005, 01:43 PM
JFellman's Avatar
Others have reported that the Summitracing.com wiring harness (p/n 890030, $39.95) with relays works wonders and also saves the headlight switch from melting down.
hipsi
07-15-2007 01:00 PM
airplaneman00
13
06-22-2007 09:20 PM
B.Law
07-18-2006 02:46 PM
mamm7215
07-15-2004 08:08 AM
brianflynhigh
03-19-2004 01:48 PM
Quick Reply: Sport Lights???
